StarTech.com 1m Lightning Cable with LED
Product codes
Know when your iPhone, iPod or iPad is fully charged. Now you can know when your Apple mobile devices are done charging, without having to access them to find out. This Lightning charging cable features an LED indicator that lets you know when your mobile devices are fully charged.
The charge cable provides a visual that lets you know when your mobile device is charging, so you don't have to doubt whether or not the cable is plugged in correctly.
The LED indicator on either side of the Lightning connector lights up when the cable is connected to your device as well as a USB charger or USB port. A red light indicates that your iPhone, iPad or iPod is still charging and a green light indicates that your device is fully charged.
Replace the cable that came with your device, or keep one as a spare in your laptop bag, backpack or other carrying case while you're on the road.
You don't have to remove the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Lightning connector molding that easily plugs into your device, even while it's inside a protective case.
Product Description StarTech.com 1m / 3 ft Apple Lightning Cable with LED Charging Light - Lightning cable - Lightning / USB - 1 m
Cable Lightning cable - Lightning / USB
Length 1 m
Connector Lightning - male
Connector (Second End) USB - male
Features Moulded, LED indicator
Designed For Apple 12.9-inch iPad Pro (1st generation, 2nd generation); iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus; iPod nano (7G); iPod touch (5G, 6G)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m Lightn...
