StarTech.com 1m Pink Mobile Charge Sync USB to Slim Micro USB...
StarTech.com 1m Pink Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets
£5.23
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 1m
  • Stock Status: In Stock
Product codes
Charge and Sync your Micro USB-equipped Smartphone or Tablet. Tired of the same old boring black cables? Want something that matches your personality?
The USBAUB1MPK 1m Pink Micro USB Cable is perfect for adding a little color to your life, and for providing a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
The cable is colored to suit your pink mobile devices but it can be used with any of your Micro USB-enabled mobile devices - so don't be afraid to be colorful and select from any of the colored Micro USB cables such as Pink, USBAUB1MGN Green, USBAUB1MYL Yellow or USBAUB1MBL Blue. You can create the perfect color match with your smartphone or tablet or be creative with your own unique look!
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
Product Description StarTech.com 1m Pink Mobile Charge Sync USB to Slim Micro USB Cable - Phones & Tablets - A to Micro B M/M - Thin Micro USB Charging Cable (USBAUB1MPK) - USB cable - 1 m
Type USB cable
Technology Double shielded
Length 1 m
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Pink
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m Pink M...
£5.23
