StarTech.com 1m USB 3.1 USB-C to USB-A Cbl
£11.48
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provide high-quality connections with a USB-IF certified USB to USB-C cable
  • Transfer data faster with this USB 3.1 cable that supports 10Gbps data transfer speeds
  • Charge your USB-C mobile devices with a USB-A charger or laptop
  • Length: 1m
  • Stock Status: In Stock
Product codes
Connect your USB Type-C devices to your laptop or desktop computer. Need to connect your new USB Type-C device to a device with a traditional-style USB-A USB port? This 1m USB-C to USB-A cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you sync your USB Type-C devices in no time at all.
Moving large files or transferring movies can be done in seconds - at twice the speed of USB 3.0 and 20x faster than USB 2.0 - all while charging your device with up to 3A, where supported.
You'll also be able to connect your USB 3.1 peripherals, such as hard drive enclosures and docks, to devices with a USB-A port. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations.
Connect your newer devices to older computers; USB 3.1 is backwards compatible with previous USB devices.
Product Description StarTech.com USB to USB C Cable - 3 ft / 1m - 10 Gbps - USB-C to USB-A - USB 2.0 Cable - USB Type C (USB31AC1M) - USB-C cable - 1 m
Type USB-C cable
Technology Double shielded
Length 1 m
Connector 24 pin USB-C - male
Connector (Second End) 9 pin USB Type A - male
Compliant Standards USB 3.1
Colour Black
Designed For P/N: 4SD4FCRU31C, BNDTBUSB3142, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DKT30CVAGPD, HB30A4AIB, HB30C4AIB, HBS304A24A, M2E1BMU31C, M2E1BRU31C, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC3, PEXUSB312C3, S251BRU31C3, SDOCK4U313, TB33A1C
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m USB 3....
£11.48
