StarTech.com 1m USB 3 Cable Right Angle BK
£7.02
Select:
  • 1m
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect to your PC, laptop or server, even if it is flush against a wall or other surface
  • Error-free data transfers
  • Guaranteed reliability
  • Length: 1m
  • Stock Status: In Stock
Product codes
Connect USB 3.0 devices, even in hard to reach areas and tight spaces. The USB3SAB1MRA 1m Black USB 3.0 A to B cable features a right-angled USB ''A'' male connector, enabling you to connect your USB 3.0 Type ''B'' peripherals to your PC, laptop, or server, even in hard to reach areas and tight spaces.
The right-angled USB ''A'' connector positions the cable nearly flush against a wall or other surface, and eliminates the space typically required to accommodate a ''straight'' connection from the cable into the USB port.
Harnessing the full capabilities of the SuperSpeed USB 3.0 standard when used with a USB 3.0 host and device, the 1m cable offers a bandwidth of 5Gbps.
Plus, this right angle USB 3.0 cable also features high quality Shielded Twisted Pair (STP) construction, which helps prevent electro-magnetic interference and ensure reliable data communication.
Product Description StarTech.com 1m Black SuperSpeed USB 3.0 Cable - Right Angle A to B - 3 ft USB 3 Cable - Right Angle USB 3.0 A (M) to USB 3.0 B (M) (USB3SAB1MRA) - USB cable - 1 m
Type USB cable
Technology Shielded twisted pair (STP)
Features Molded, right-angled connector, 5 Gbps data rate
Length 1 m
Connector 9 pin USB Type B - male
Connector (Second End) 9 pin USB Type A - male
Compliant Standards USB / USB 2.0 / USB 3.0
Colour Black
Designed For P/N: HB30A4AIB, HB30C4AIB, HB31C4AB, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S3520BU33ER, S352BU313R, S352BU33HR, S355BU33ERM, SDOCK2U313R, SDOCKU33EF
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m USB 3...
£7.02
