StarTech.com 1m USB C Cable - USB 3.0
£15.52
26 in stock
Delivery:
Standard: 1-3 working days
Product codes
Connect your USB Type-C devices. This USB 3.0 USB-C to USB-C cable lets you connect a USB 3.0, USB Type-C device, such as a hard drive or mobile device, to the USB-C port on your computer, or charger. The cable is also compatible with Thunderbolt 3 ports.
Connect your newer USB-C mobile devices, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones, to your computer. The cable delivers up to a 3 amp (60W) charge, and supports data transfer speeds of up to 5Gbps.
With up to 3A of power output, you can also use the USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect your laptop to your USB-C wall charger.
You'll also be able to connect your USB 3.0 peripheral devices, such as hard drive enclosures and docks, to your laptop.
StarTech.com 1m 3 ft USB C to USB C Cable - M/M - USB 3.0 (5Gbps) - USB-C cable - 1 m
USB-C cable
Double shielded
4K support, Power Delivery (PD) technology
Length
1 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.2
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m USB C...
£15.52
