StarTech.com 1m White Thunderbolt Cable - M/M
£36.76
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with Thunderbolt 1 and Thunderbolt 2 specifications
  • Supports Power-over-cable, for bus-powered Thunderbolt devices
  • Supports native peer-to-peer file sharing when supported by the OS
  • Length: 1m
  • Stock Status: In Stock
Product codes
The Thunderbolt cables deliver the dependability you need to harness the speed and power of Thunderbolt technology and combine both data and video into a single high-performance cable.
You can find the perfect connection to suit any application, with the wide range of Thunderbolt cables. Compatible with Thunderbolt 1 (10 Gbps) and Thunderbolt 2 (20 Gbps) devices, the cables support bi-directional data transfer capability and power delivery for bus-powered devices. All of the Thunderbolt cables are constructed of highly durable materials and designed to the highest quality standards. Plus, the optical cables use optical fiber instead of copper so you don't need to worry about signal loss or EMI interference.
Product Description StarTech.com 1m White Thunderbolt Cable - M/M - Thunderbolt cable - 1 m
Type Thunderbolt cable
Technology Double shielded
Length 1 m
Connector Mini DisplayPort - male
Connector (Second End) Mini DisplayPort - male
Compliant Standards Thunderbolt 2
Colour White
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m White...
£36.76
