StarTech.com 1S1P Native PCI Express Parallel Serial Combo Ca...
StarTech.com 1S1P Native PCI Express Parallel Serial Combo Card with 16950 UART
£37.38
Delivery:
Standard: 1-3 working days
Key features
  • Native single chip, single lane PCI Express
  • 1 high-speed RS232 serial port and 1 IEEE 1284 parallel port
  • Compliant with PCI Express base
  • Automated in-band flow control using programmable Xon/Xoff
  • 128-byte deep FIFO per transmitter and receiver
  • Selectable power output on pin 9 of the serial port
  • Type: Parallel/serial adapter
  • Compatibility: PC
  • Interface: PCI Express
  • Stock Status: In Stock
Product codes
The PEX1S1P952 1S1P native PCI Express parallel/serial combo card with 16950 UART turns a PCI Express slot into 1 RS232 (DB9) serial, and 1 parallel port.
The combo card features a native PCI Express single chip design that allows you to take advantage of full PCI Express capability, providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional serial cards that use a bridge chip design.
This 1-port serial/1-port parallel card offers compatibility with a broad range of operating systems, for easy integration into mixed environments.
Product Description StarTech.com 1S1P Native PCI Express Parallel Serial Combo Card with 16950 UART - parallel/serial adapter
Device Type Parallel/serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express
PCI Specification Revision PCIe 1.1
Dimensions (WxDxH) 12 cm x 8 cm x 6.5 cm
Weight 60 g
Data Link Protocol Parallel, RS-232
System Requirements Microsoft Windows 2000 Server, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1S1P Nati...
£37.38
