StarTech.com 1U 60x10mm Socket 7/370 CPU Cooler Fan with Copp...
StarTech.com 1U 60x10mm Socket 7/370 CPU Cooler Fan with Copper Heatsink & TX3
£12.91
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Add a copper heatsink cooler for a Socket 7/370 CPU for a 1U server. This 60x10mm Socket 7/370 CPU Cooler helps keep your 1U servers running smoothly, by providing a reliable, cost-effective server cooling solution.
The server CPU cooler features a copper base and socket-type CPU fan, ensuring rapid heat dissipation in the reduced space of a 1U server environment.
The CPU cooler is powered through a simple TX3 connection to the server power supply, and is suitable for all Intel Celeron/PIII processors and AMD Athlon/Duron processors up to 1GHz.
StarTech.com 1U 60x10mm Socket 7/370 CPU Cooler Fan w/ Copper Heatsink & TX3 - processor cooler
Processor cooler
Compatibility
Socket A, Socket 370
Heatsink Material
Copper
Fan Diameter
60 mm
Fan Height
10 mm
Rotation Speed
5000 rpm
Air Flow
13.5 cfm
Noise Level
31 dBA
Power Connector
3-pin plug
Ball bearing
Product Material
Copper
0.2 kg
1-year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1U 60x10m...
£12.91
