StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive...
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm
£19.64
Delivery:
Standard: 1-3 working days
  • Type: Adapter
  • Stock Status: In Stock
Product codes
Turn a 2.5" SATA HDD/SSD into a 3.5" SATA Drive. The 25SAT35HDD 2.5" to 3.5" hard drive adapter enclosure turns a 2.5" SATA hard drive (HDD) or solid state drive (SSD) into a 3.5" drive.
The adapter enclosure lets you substitute a 3.5" hard drive for a 2.5" SSD/HDD in any application that would typically require a 3.5" drive, such as desktop chassis, backplane, or docking station. The enclosure has the same dimensions as a standard 3.5" hard drive, including mounting points, and SATA connector locations.
With support for drives up to 12.5mm in height, and high-capacity SATA I/II/III drives (tested up to 1TB) this HDD adapter ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
Product Description StarTech.com 2.5" SSD/HDD to 3.5" SATA Aluminum HDD Adapter Enclosure - storage enclosure - SATA 6Gb/s - SATA 6Gb/s
Device Type Storage enclosure - internal
Bus Type SATA 6Gb/s
Expansion Bays 1 x internal - 2.5" x 1/8H
Compatible Bay 1 3.5" x 1/3H
Hard Drive Form Factor Compatibility 2.5"
Supported Interface SATA-600
Drive Connector 22 pin Serial ATA
Bay Connector 22 pin Serial ATA
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Product Material Plastic, aluminium
Dimensions (WxDxH) 10.15 cm x 4.75 cm x 2.55 cm
Weight 216 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2.5" to 3...
£19.64
