StarTech.com 2.5 to 3.5 Hard Drive Adapter
£26.17
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Adapter
  • Stock Status: In Stock
Product codes
Turn almost any 2.5" SATA/SAS drive into a 3.5" drive. This 2.5" to 3.5" hard drive adapter lets you install a 2.5" SATA or SAS hard drive (HDD) or solid-state drive (SSD) into an internal or external 3.5" drive bay, using standard drive-mounting holes.
The 2.5" to 3.5" hard drive bay adapter lets you install a newer, higher performance drive such as an SSD into a legacy system that may only support a 3.5" hard drive. It provides a cost-efficient way to enhance storage performance and reliability without expensive upgrades to core IT systems. It's also ideal for system administrators who want to build a system that takes advantage of the increased performance of a 2.5" HDD/SSD.
To utilize the full speed potential of your SATA/SAS drive, the adapter supports transfer speeds up to 6Gbps.
You can install the adapter into a desktop, server, storage-array, hot-swap bay, and drive drawer. It offers permanent installation in a 3.5" drive bay with standard mounting holes. When the adapter is installed, you simply slide a 2.5" HDD/SSD into the adapter enclosure, with no tools required.
The adapter is suitable for drives with a height of up to 15 mm. Virtually any 2.5" SATA/SAS drive can be made to look and function like a 3.5" drive.
The adapter includes a label you can use to track and record information about the installed drive.
Product Description StarTech.com 2.5" to 3.5" Hard Drive Adapter - For SATA and SAS SSDs/HDDs - storage enclosure - SATA 6Gb/s / SAS 6Gb/s - SAS 6Gb/s, SATA 6Gb/s
Device Type Storage enclosure - internal
Bus Type SAS 6Gb/s, SATA 6Gb/s
Colour Black, silver
Expansion Bays 1 x internal - 2.5" x 1/8H
Compatible Bay 1 3.5" x 1/3H
Hard Drive Form Factor Compatibility 2.5"
Supported Interface SATA-600 / SAS 2.0
Drive Connector 29 pin internal SAS (SFF-8482)
Bay Connector 22 pin Serial ATA
Interface SATA 6Gb/s / SAS 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Product Material Plastic, aluminium
Dimensions (WxDxH) 10.1 cm x 14.6 cm x 2.6 cm
Weight 252 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2.5 to 3....
£26.17
