Turn almost any 2.5" SATA/SAS drive into a 3.5" drive. This 2.5" to 3.5" hard drive adapter lets you install a 2.5" SATA or SAS hard drive (HDD) or solid-state drive (SSD) into an internal or external 3.5" drive bay, using standard drive-mounting holes.
The 2.5" to 3.5" hard drive bay adapter lets you install a newer, higher performance drive such as an SSD into a legacy system that may only support a 3.5" hard drive. It provides a cost-efficient way to enhance storage performance and reliability without expensive upgrades to core IT systems. It's also ideal for system administrators who want to build a system that takes advantage of the increased performance of a 2.5" HDD/SSD.
To utilize the full speed potential of your SATA/SAS drive, the adapter supports transfer speeds up to 6Gbps.
You can install the adapter into a desktop, server, storage-array, hot-swap bay, and drive drawer. It offers permanent installation in a 3.5" drive bay with standard mounting holes. When the adapter is installed, you simply slide a 2.5" HDD/SSD into the adapter enclosure, with no tools required.
The adapter is suitable for drives with a height of up to 15 mm. Virtually any 2.5" SATA/SAS drive can be made to look and function like a 3.5" drive.
The adapter includes a label you can use to track and record information about the installed drive.
Product Description | StarTech.com 2.5" to 3.5" Hard Drive Adapter - For SATA and SAS SSDs/HDDs - storage enclosure - SATA 6Gb/s / SAS 6Gb/s - SAS 6Gb/s, SATA 6Gb/s | Device Type | Storage enclosure - internal | Bus Type | SAS 6Gb/s, SATA 6Gb/s | Colour | Black, silver | Expansion Bays | 1 x internal - 2.5" x 1/8H | Compatible Bay | 1 3.5" x 1/3H | Hard Drive Form Factor Compatibility | 2.5" | Supported Interface | SATA-600 / SAS 2.0 | Drive Connector | 29 pin internal SAS (SFF-8482) | Bay Connector | 22 pin Serial ATA | Interface | SATA 6Gb/s / SAS 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive, solid state drive | Product Material | Plastic, aluminium | Dimensions (WxDxH) | 10.1 cm x 14.6 cm x 2.6 cm | Weight | 252 g | Manufacturer Warranty | 2-year warranty |
General | |
Hard Drive Maximum Height | 15 mm |
Host Bus | SAS 6Gb/s, SATA 6Gb/s |
Storage Controller | |
Expansion / Connectivity | |
Interfaces | 1 x SATA 6Gb/s |
Connections | 1 - 22 pin Serial ATA |
Compatible Bay | 1 x internal 3.5" x 1/3H |
Miscellaneous | |
Features | Hot-swappable, S.M.A.R.T. support, TRIM support, 4Kn drive compatible |
Mounting Kit | Included |
Compliant Standards | FCC, RoHS, WEEE |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 10.1 cm |
Depth | 14.6 cm |
Height | 2.6 cm |
Weight | 252 g |
Dimensions & Weight (Shipping) | |
Shipping Weight | 252 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 5 - 65% |
