StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mountin...
StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit
£7.53
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A metal mounting bracket ensures the drive is reliably secure and provides heat dissipation from the drive
  • Stock Status: In Stock
Product codes
Mount a 2.5in SATA hard drive to any desktop with an available 3.5in bay. This Serial ATA hard drive mounting kit allows you to install a 2.5in SATA hard drive in a 3.5in drive bay. The 2.5in to 3.5in SATA hard drive mounting kit features a sturdy aluminum bracket, as well as a combined 7+15 pin SATA + LP4 Power to SATA cable - which helps simplify installation and reduce clutter within the computer case.
Product Description StarTech.com 2.5in Hard Drive to 3.5in Drive Bay Mounting Kit - storage bay adapter
Device Type Storage bay adapter
Expansion Bays 1 x internal - 2.5"
Compatible Bay 1 3.5"
Product Material Aluminium
Dimensions (WxDxH) 9.8 cm x 10 cm x 1 cm
Weight 110 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2.5in SAT...
£7.53
