StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive...
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter
£14.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Turn Virtually any 2.5" SATA or SAS Hard Drive into a 3.5" SATA Drive. The 25SATSAS35 2.5-inch SATA/SAS to 3.5-inch SATA Hard Drive Converter converts a 2.5-inch SATA or SAS hard drive (HDD) or solid state drive (SSD) into a 3.5-inch form factor SATA Hard Drive.
The converter provides a versatile solution for 2.5-inch drive installations, enabling you to install a 2.5-inch SATA/SAS drive in a 3.5-inch bay, drive drawer caddy/tray, or into a 3.5-inch drive enclosure.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Suitable for drives with a height of up to 15mm, virtually any 2.5-inch SATA or SAS hard drive can be made to look and function like a 3.5-inch hard drive - complete with standard mounting points along the sides and bottom (including 3 points along the sides for compatibility with some Dell systems).
The Drive Converter features a trayless design for simple drive installation and removal, and is constructed of durable, yet lightweight plastics, with ventilation openings to aid air flow and help keep hard drives running cooler.
Product Description StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter - storage bay adapter
Device Type Storage bay adapter
Colour Black
Supported Form Factor 3.5" to 2.5"
Expansion Bays 1 x internal - 2.5"
Compatible Bay 1 3.5"
Product Material Plastic
Dimensions (WxDxH) 10.1 cm x 14.6 cm x 2.5 cm
Weight 135 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2.5in SAT...
£14.67
