StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive E...
StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP
£18.64
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 70% Faster than traditional USB 3.0, with UASP Transfer Protocol
  • Maximum portability, with USB powered enclosure and Tool-less HDD installation
  • Type: Storage enclosure
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Turn a 2.5" SATA Hard Drive or Solid State Drive into a UASP supported USB 3.0 External Hard Drive. The S2510BPU33 USB 3.0 Hard Drive Enclosure with UASP lets you connect a 2.5in SATA III hard drive (HDD) or solid state drive (SSD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 2.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 1TB) this HDD enclosure is compatible with virtually any 2.5in SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
For added portability the USB 3.0/SATA III enclosure features tool-less HDD installation, and requires no external power adapter.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
Product Description StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP - Portable External USB HDD with Tool-less Installation (S2510BPU33) - storage enclosure - SATA 6Gb/s - USB 3.0
Device Type Storage enclosure - external
Bus Type USB 3.0
Colour Black
Expansion Bays 1 x internal - 2.5"
Hard Drive Form Factor Compatibility 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 5 GBps
Supported Devices Hard drive
Max Storage Devices Qty 1
Product Material Plastic
Power Source USB bus
System Requirements Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Dimensions (WxDxH) 8.8 cm x 13.19 cm x 1.5 cm
Weight 70.1 g
Designed For P/N: USB3VDOCKD, USBDUP15, USBDUPE115, USBDUPE17
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2.5in USB...
£18.64
