StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack...
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
£43.35
35 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 50000 times insertion/removal cycle
  • Stock Status: In Stock
Product codes
Easy, trayless removal and insertion of dual 2.5in SATA hard drives from single 3.5in bay. This 3.5in SATA hard drive hot-swap bay allows you to install two 2.5in SATA hard drives (HDD) or solid state drives (SSD) in an available/unused 3.5in floppy drive bay.
Featuring a convenient "no mounting required /easy eject" feature (like a tape cartridge or floppy disk), the hard drive hot swap bay doesn't require that the drives be installed in a tray - making it the ideal solution for quick and easy drive removals and insertions as part of a system building process, or integration into rackmount systems or industrial environments.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Also a perfect addition for operating system image deployment and any task that requires being able to quickly access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
With support for SATA HDD speeds up to 6.0 Gbps, this backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
Product Description StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane - storage bay adapter
Device Type Storage bay adapter
Colour Black
Expansion Bays 2 x hot-swap - 2.5"
Compatible Bay 1 3.5"
Product Material Aluminium
Dimensions (WxDxH) 10.2 cm x 13.4 cm x 2.4 cm
Weight 283 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Drive 2...
£43.35
