StarTech.com 2 ft Cat5e Red Snagless RJ45 UTP Cat 5e Patch Cable
£2.97
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector clip protectors
  • Carefully constructed and tested, to keep Near End Crosstalk (NEXT) well within acceptable limits
  • Colored hoods for departmental color coding
  • Molded strain relief prevents the cable from being bent at sharp angles at the RJ45 connector, to minimize the stress at the plug termination point
  • Constructed with top quality components
  • High quality 24 AWG copper wire
  • Length: 0.6m
  • Colour: Red
  • Stock Status: In Stock
Product codes
The 45PATCH2RD CAT5e Patch Cable meets or exceeds all CAT5e specifications to ensure reliable Ethernet network connections, and features a durable PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality CAT5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
Product Description StarTech.com Cat5e Ethernet Cable - 2 ft - Red- Patch Cable - Snagless Cat5e Cable - Short Network Cable - Ethernet Cord - Cat 5e Cable - 2ft (45PATCH2RD) - patch cable - 0.6 m - red
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wires per Cable 8 wires
Features Snagless
Length 0.6 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 ft Cat5...
£2.97
