StarTech.com 2 ft Cat5e Yellow Molded RJ45 UTP Cat 5e Patch C...
StarTech.com 2 ft Cat5e Yellow Molded RJ45 UTP Cat 5e Patch Cable
£2.95
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
  • Length: 0.6m
  • Colour: Yellow
  • Stock Status: In Stock
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT2YL Cat5e Patch Cable (2 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description StarTech.com 2 ft Yellow Cat5e / Cat 5 Molded Patch Cable 2ft - patch cable - 0.6 m - yellow
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568A
Wires per Cable 8 wires
Features Molded
Length 0.6 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Yellow
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 ft Cat5...
£2.95
