StarTech.com 2 ft Panel Mount USB Cable A to A - F/M
£5.28
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 60cm
  • Stock Status: In Stock
Product codes
Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM2 2ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 2ft, enabling you to place the cable as needed within the system case.
Product Description StarTech.com 2 ft Panel Mount USB Cable A to A F/M - Panel Mount USB Extension USB A-Female to A-Male Adapter Cable 2ft - USB-A (F) Port (USBPNLAFAM2) - USB extension cable - 60 cm
Type USB extension cable
Technology Double shielded
Features Molded, thumbscrews
Length 60 cm
Connector 4 pin USB Type A - female
Connector (Second End) 4 pin USB Type A - male
Colour Black
Designed For P/N: UUSBOTG
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 ft Pane...
£5.28
