StarTech.com 2 Port 16in DB9 Serial Port Bracket to 10 Pin He...
StarTech.com 2 Port 16in DB9 Serial Port Bracket to 10 Pin Header
£6.64
35 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Save space by adding two DB9 serial ports through a single expansion slot on the back of your PC
  • Stock Status: In Stock
Product codes
Add two extra serial ports to the back of your PC, from your motherboard. The PLATE9M2P16 Dual Port Serial Plate adds two DB9 serial ports to the rear panel of a computer, connecting to two IDC10 header connectors on the motherboard.
Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
Product Description StarTech.com 2 Port 16in DB9 Serial Port BRacket to 10 Pin Header - DB9 bRacket - DB9 Header - Serial Port bRacket (PLATE9M2P16) - serial panel - 40.64 cm
Type Serial panel
Length 40.64 cm
Connector 2 x 9 pin D-Sub (DB-9) - male
Connector (Second End) 2 x 10 PIN IDC - female
Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port 16...
£6.64
