StarTech.com 2 Port 2-to-1 USB 3.0 Peripheral Sharing Switch...
CLEARANCE
CLEARANCE
LAST FEW REMAINING
LAST FEW REMAINING
PRICE DROP
PRICE DROP
StarTech.com 2 Port 2-to-1 USB 3.0 Peripheral Sharing Switch – USB Powered
PRICE DROP!
£29.85
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Product codes
Share a single USB 3.0 device between two different computers. The USB221SS 2-to-1 USB 3.0 Peripheral Sharing Switch lets you share a single USB 3.0 peripheral with 2 different computer systems, avoiding the cost of purchasing duplicate peripherals or the hassle of swapping cables from one system to another.
The USB sharing switch delivers speed and flexibility, with simple push-button controls for switching between computers, and support for SuperSpeed USB bandwidth (up to 5 Gbps) ensuring fast data transfers to/from your shared peripheral device. The switch is also backward compatible with USB 2.0/1.1 (480Mbps, 12Mbps respectively), so you don't have to worry about your computer or older peripherals not performing.
The 2-port USB switch can also be connected to a USB hub, to expand the number of devices you can share between the two connected systems, or to a USB drive enclosure or docking station, for a shared external storage solution.
The switch features a compact design that takes up minimal desk space and is USB-powered, so it doesn't require an AC wall outlet.
StarTech.com 2 Port 2-to-1 USB 3.0 Peripheral Sharing Switch - USB peripheral sharing switch - 2 ports
Subtype
USB
Ports
2 x SuperSpeed USB 3.0
USB powered
USB 2.0, USB 3.0
4.2 cm x 6.9 cm x 2.2 cm
40 g
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port 2-...
£29.85
