StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter...
StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card
£64.94
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Experience the power and speed of FireWire 800 and ExpressCard
  • Hot swap capabilities allow you to connect or disconnect devices without turning off the host computer
  • Supports data transfer rates of up to 100, 200, 400 and 800 Mbps
  • Supports various types of FireWire 800 (1394B) and 1394A standards
  • Type: FireWire adapter
  • Compatibility: PC
  • Interface: ExpressCard/34
  • Stock Status: In Stock
Product codes
Documents
This 2 Port ExpressCard FireWire Adapter Card adds two 1394b FireWire ports to a laptop computer, providing a cost-effective way to add IEEE 1394A and IEEE 1394B FireWire devices even if the laptop doesn't have a built-in FireWire 400 or FireWire 800 port. Simply insert the IEEE 1394B FireWire 800 card (EC1394B2) into an ExpressCard slot, and you'll be able to connect a broad range of FireWire devices to your laptop, while relying on data transfer speeds of up to 800Mbps. Plus, the card is backward compatible with 1394a devices, so you can connect both FireWire 400 and 800 devices to the notebook, using the same adapter.
Product Description StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card - Texas Instruments FireWire Card - ExpressCard FireWire 800 (EC1394B2) - FireWire adapter
Device Type FireWire adapter
Form Factor Plug-in module
Interface (Bus) Type ExpressCard/34
Ports FireWire 800 x 2
Dimensions (WxDxH) 3.4 cm x 12 cm x 2 cm
Weight 30 g
Data Link Protocol FireWire 800
Data Transfer Rate 800 Mbps
System Requirements Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits)
Resources
The following resources are available for the StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Ex...
£64.94
