Extend two Power over Ethernet devices by 100 meters, or daisy chain up to four extenders for longer distance. This 2-port Gigabit PoE+ extender spans your Power over Ethernet (PoE) devices over longer distances, letting you double the 100 m limitation of a traditional PoE infrastructure.
Now you can connect two Gigabit PoE devices up to a maximum of 200 m away, so it's easy to install a remote IP camera or access point where you need it. Plus, you can daisy-chain the extender for more scalability.
Need more distance? This convenient two-port PoE+ repeater maximizes range and flexibility by extending your PoE connections by an extra 100 m (330 ft.), while providing 23-watt power output to two compatible devices. (The power output is shared between each PoE output port).
Simply connect the extender to your power sourcing equipment (PSE) and your PoE-powered devices (PD) and you're all set. The extender is compliant with the 802.3at/af standard, so it will work with existing PSE, such as a StarTech.com PoE+ injector (POEINJ1G) or PoE+ switch (IES81000POE).
Still need more distance? If an extra 100 m isn't enough, this full-featured PoE extender offers daisy-chain capability.
You can easily connect four extenders together, letting you install two PoE+ PDs up to 500 m (1640 ft.) away. It's perfect for business, education, and retail environments. (Output wattage is dependent on the number of daisy-chained extenders used, and the number of connected PoE devices).
Get up and running quickly. This 2-port Gigabit PoE+ extender can be positioned right where you need it, with a wall-mountable design that requires no external power adapter.
With its rugged metal housing and built-in ESD and surge protection, the PoE+ extender gives you reliable performance with little worry of downtime or failure.
