StarTech.com 2 Port Industrial PCI Express PCIe RS232 Serial...
StarTech.com 2 Port Industrial PCI Express PCIe RS232 Serial Card w/ Power Output and ESD Protection
Key features
  • Communicate efficiently with connected devices with high-speed 921Kbps support
  • Power connected serial devices on pin 1 and/or pin 9 with flexible per-port power output settings
  • Protect your system from damage with integrated ESD Protection
Product codes
Add two high speed, ESD-Protected RS232 ports, with 5V or 12V selectable power output through a PCI Express slot. The PEX2S553S 2-Port PCI Express Serial Card lets you add twoESD-Protected RS232 ports with 5V or 12V selectable power output, through a PCI Express slot.
Ideal for industrial environments, this 2-port serial card offers built-in 15KV ESD-protection which helps prevent damage to connected devices in the event of line surges and electro-static discharge. An extended operating temperature range (-30°C to 75°C) also helps to ensure performance in harsh environments.
For devices that require additional power, this serial controller has a jumper-selectable 5V or 12V power output option (pin 1 and/or pin 9), through an LP4 connection to your power supply. For added flexibility, the power output can be enabled or disabled on a per-port basis so you choose which port(s) supply power.
This versatile RS232 card supports high-speed serial data rates up to 921.6 Kbps, and is compliant with PCIe Gen 2.0 specifications for added bandwidth. To maximize installation options, the 2-port card is equipped with a standard profile bracket and includes an optional low-profile/half-height bracket for installation in small form factor computers.
StarTech.com 2 Port Industrial PCIe RS232 Serial Card w/ Power and ESD - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0
Ports
RS-232 x 2
1.8 cm x 12.1 cm x 9.8 cm
35 g
RS-232
Data Transfer Rate
921.6 Kbps
Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Windows 10 (32/64 bits)
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port In...
