StarTech.com 2 Port Industrial USB to Serial RJ45 Adapter - W...
StarTech.com 2 Port Industrial USB to Serial RJ45 Adapter - Wallmount and DIN Rail
£29.53
Delivery:
Key features
  • Multiple ports with COM port retention give you hassle-free control of several serial devices, without having to remember where each one was last connected
  • Rugged all-metal enclosure with included DIN Rail and Wallmount brackets for versatile installation options and added durability
  • The USB to RJ45 Serial Adapter draws its power from the USB host connection, eliminating the need for bulky external adapters or power outlets
Product codes
Add two RS232 serial RJ45 connections to a PC or Server through USB, with this DIN Rail and wall-mountable adapter. The ICUSB2322RJ 2-Port Industrial USB to Serial RJ45 Adapter (Wallmount and DIN Rail) allows you to add two RS232 serial connections using RJ45 signaling ports to a PC or Server through a single USB 2.0 port. The RS232 to RJ45 adapter features COM port retention to maintain your port number assignments across a reboot and supports serial data rates up to 921 Kbps. The included DIN Rail clips (Top Hat) and wall-mounting brackets provide simple solutions for out of the way installations, while the sturdy metal enclosure offers durability in harsh industrial environments.
StarTech.com 2 Port Industrial USB to Serial RJ45 Adapter - Wallmount and DIN Rail - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 2
4.2 cm x 6.5 cm x 2 cm
78 g
RS-232
Data Transfer Rate
921.6 Kbps
Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Apple MacOS X 10.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port In...
£29.53
