StarTech.com 2 Port Industrial Wall Mountable USB to Serial A...
StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips
£47.95
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy plug and play installation, with our USB Powered adapter - no power outlet required
  • Integrated wallmount brackets and included DIN Rail clips for versatile mounting options
  • Rugged all-metal enclosure for added durability in harsh environments
  • Type: Serial adapter
  • Compatibility: Mac, PC
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
The ICUSB2322I 2-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into two RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter.
Product Description StarTech.com 2 Port Wall Mount USB to Serial Hub Adapter w/ DIN Rail Clips - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports RS-232 x 2
Dimensions (WxDxH) 5.6 cm x 10.4 cm x 2.5 cm
Weight 400 g
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Processor FTDI
Colour Black
System Requirements Microsoft Windows CE, Microsoft Windows 2000 Server, Apple MacOS X 10.x, Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port In...
£47.95
