StarTech.com 2 Port Internal USB 3.0 Motherboard Header Adapt...
StarTech.com 2 Port Internal USB 3.0 Motherboard Header Adapter Cable
£15.43
Delivery:
Standard: 1-3 working days
  • Length: 15.24cm
  • Stock Status: In Stock
Product codes
Connect 2 internal USB 3.0 devices (internal card reader, hard drive) directly to a motherboard header connection. The USB3SMBADAP6 Internal USB 3.0 Adapter Cable extends a 20-pin motherboard USB 3.0 header connection and enables you to add 2 internal female USB 3.0 (Type A) ports.
With the addition of the 2 internal USB 3.0 ports, you can connect your internal devices (internal card reader, hard drive, etc.) directly to your motherboard, which allows for a cleaner installation, avoiding the need to run your cables outside the system case to external USB 3.0 ports.
This USB 20-pin Adapter offers 6-inches in cable length, which lessens strain on the motherboard header, ensuring a reliable, long-lasting connection.
Product Description StarTech.com 2 Port Internal USB 3.0 Motherboard Header Adapter Cable - Internal 20-pin Header to 2x USB 3.0 A Female Adapter Cable - 6in (USB3SMBADAP6) - USB internal adapter - 15.24 cm
Type USB internal adapter
Technology Shielded
Length 15.24 cm
Connector 2 x 9 pin USB Type A - female
Connector (Second End) 20 pin USB 3.0 header - female
Compliant Standards USB / USB 2.0 / USB 3.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port In...
£15.43
