StarTech.com 2 Port Low Profile Native RS232 PCI Express Seri...
StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART
£31.83
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: Mac, PC
  • Interface: PCI Express
  • Stock Status: In Stock
Product codes
The PEX2S553LP low profile/half-height PCI Express serial card turns a PCI Express slot into two RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 serial adapter card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64-bit), Linux Kernel 2.6.11 and up, and ships with a low profile/half-height bracket installed but includes an optional full profile bracket that lets you add 2 serial ports to virtually any computer (regardless of the case form factor).
This product is a replacement for the PEX2S552LP card.
Product Description StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART - PCIe RS232 - PCI-E Serial Card (PEX2S553LP) - serial adapter
Device Type Serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express
Ports RS-232 x 2
Dimensions (WxDxH) 2 cm
Weight 63.5 g
Cabling Type Serial RS-232
System Requirements Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4 - 10.7, Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Lo...
£31.83
