StarTech.com 2 Port Low Profile Native RS232 PCI Express Seri...
StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART
£33.42
Delivery:
  • Type: Serial adapter
  • Compatibility: PC, Unix
  • Interface: PCI Express x1
Product codes
The StarTech.com PEX2S952LP low profile/half-height PCI Express Serial Card turns a PCI Express slot into two RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and ships with a low profile bracket installed but includes an optional full profile bracket that lets you add two serial ports to virtually any computer (regardless of the case form factor).
Product Description StarTech.com 2 Port Low Profile Native PCI Express Serial Card w/ 16950 - Serial adapter - PCI Express low profile - RS-232 - serial adapter
Device Type Serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.0a
Ports RS-232 x 2
Dimensions (WxDxH) 2 cm x 9 cm x 8 cm
Weight 58 g
Data Link Protocol RS-232
Data Transfer Rate 460.8 Kbps
Processor 1 x OXPCIe952 - Oxford Semiconductor
System Requirements Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Lo...
£33.42
