StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter -...
StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter - F/M
£8.42
10 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Add two eSATA ports to your PC, extended from internal Serial ATA connection ports. The ESATAPLT2LPM SATA to eSATA Plate Adapter (low profile/half-height) adds external data support to any existing Serial ATA (SATA) controller, enabling you to connect external SATA (eSATA) storage to a computer. With support for data transfer rates of up to 6 Gbps, this external SATA plate lets you take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections.
Connecting your eSATA storage couldn't be simpler - just install this plate into an open I/O low profile slot on your computer and connect your cables to the Serial ATA connectors on your motherboard or controller card. The SATA connector provides a secure connection to the motherboard or controller card, and is designed to take up minimal space inside the computer case, providing less clutter and increased airflow inside your case.
Product Description StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter - F/M - SATA to eSATA adapter
Type SATA to eSATA adapter
Interface Speed Serial ATA 150/300/600
Connector 2 x 7 pin Serial ATA - male
Connector (Second End) 2 x 7 pin external Serial ATA - male
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Lo...
£8.42
