StarTech.com 2 Port Native ExpressCard RS232 Serial Adapter C...
StarTech.com 2 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART
£52.29
Delivery:
Product codes
Add 2 high-speed RS-232 Serial ports to your notebook computer via an ExpressCard slot. This 2 Port ExpressCard-based Serial Card lets you add 2 RS232 serial ports to your laptop or ExpressCard equipped desktop computer, using an available ExpressCard slot.
Featuring 128-byte FIFO communication, and a high performance 16C950 UART, the ExpressCard Serial Adapter card offers baud rates up to 115.2Kbps, which ensures peak communication with your serial peripheral devices.
The serial card is designed based on a single-chip architecture (as opposed to cards that use a "bridge chip"), providing native PCI Express communication for greater performance and reliability, as well as reduced power consumption and CPU load.
Compatible with ExpressCard /34mm and ExpressCard 54mm card slots, the 2 Port Serial ExpressCard includes a slot spacer for greater security while installed in 54mm slots.
Product Description StarTech.com 2 Port Native ExpressCard RS232 Serial Adapter Card with 16952 UART - serial adapter
Device Type Serial adapter
Form Factor Plug-in module
Interface (Bus) Type ExpressCard/34
Ports RS-232 x 2
Dimensions (WxDxH) 4.5 cm x 11.5 cm x 2 cm
Weight 34 g
Data Link Protocol RS-232
Data Transfer Rate 460 Kbps
System Requirements Microsoft Windows 95/98/ME/XP, Microsoft Windows Vista
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Na...
£52.29
