StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Moth...
StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F
£13.32
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Enables you to extend your USB interface and provide a panel mount connector for your USB 3.0 devices
  • Easy to use and install
  • Backed by StarTech.com lifetime warranty
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Extend a USB 3.0 Motherboard Header into Two Panel-mount USB 3.0-A Ports. The USB3SPNLAFHD 2-Port USB 3.0 to Panel mount USB cable features a 20-pin USB 3.0 motherboard header connection on one end, breaking off into two separate USB 3.0-A (female) ports on the other end of the cable.
The USB 3.0 panel mount cable offers a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB 3.0 connection.
Product Description StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F - USB internal to external cable - 50 cm
Type USB internal to external cable
Technology Shielded
Length 50 cm
Connector 2 x 9 pin USB Type A - female
Connector (Second End) 20 pin IDC - female
Compliant Standards USB 3.0
Colour Blue
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Pa...
£13.32
