StarTech.com 2 Port PCI Express / PCI-e Parallel Adapter Card...
StarTech.com 2 Port PCI Express / PCI-e Parallel Adapter Card – IEEE 1284 with Low Profile Bracket
£47.38
Delivery:
Standard: 1-3 working days
Key features
  • Use existing parallel devices with PCI Express systems saving the cost and hassle of upgrading peripherals to work with newer systems
  • Standard and low profile bracket included allowing install into almost any system
  • Supports SPP, EPP, ECP and PS/2 communication modes for maximum compatibility with your parallel peripherals
  • Type: Parallel adapter
  • Compatibility: PC
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
Add 2 high-speed IEEE 1284 parallel ports (EPP/ECP/SPP/PS2) to your desktop computer through a PCI Express expansion slot. The PEX2PECP2 2 Port PCI Express Parallel Adapter Card - EPP/ECP/SPP/PS2 parallel card adds two IEEE 1284 parallel ports to your PC, with support for parallel data communication at speeds of up to 1.5 Mbps.
This high performance 2 Port PCI Express parallel card adds 2 DB25 parallel ports, perfect for connecting printers, scanners, memory card readers, bar code scanners and more. With the added convenience of plug-and-play capability, installing the parallel adapter card is hassle-free. The PCIe Parallel card also includes both standard and half-height/low profile mounting brackets for compatibility with almost any system form factor.
Product Description StarTech.com 2 Port PCI Express / PCI-e Parallel Adapter Card - IEEE 1284 with LP Bracket - 2x DB25 (F) PCIE Parallel Port Card (PEX2PECP2) - parallel adapter
Device Type Parallel adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x1
Ports IEEE 1284 x 2
Dimensions (WxDxH) 1.9 cm x 12.1 cm x 6.7 cm
Weight 60 g
Data Link Protocol Parallel
Data Transfer Rate 1.5 Mbps
System Requirements Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port PC...
£47.38
