StarTech.com 2 Port PCI Express RS232 Serial Adapter Card
£41.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Add RS232 DB9 capabilities without purchasing a new server or computer
  • PCI Express 1.1 compliant, ensuring a reliable performance
  • Maximize case form factor integration with a low-profile or full profile bracket
  • High-speed data transfer rates of up to 921.6Kbps
  • Supports 256-byte depth FIFO per transmitter and receiver
  • Type: Serial adapter
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
PCI Express to Serial Adapter 921.6Kbps Windows and Linux Compatible. This multiport PCI Express RS232 serial adapter card lets you add two RS232 (DB9) serial ports to your computer through a PCI Express (PCIe) slot, as if they were native serial ports. The dual port PCIe serial card enables you to interact with serial devices, such as card readers, printers, PIN pads, and modems, at speeds of up to 921.6Kbps.
Maximum Compatibility
With broad OS support, including for Windows and Linux, this 2 port PCI E serial card is easy to integrate into mixed environments. The card comes pre-configured with a full-profile bracket, and includes optional low-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PEX2S952(LINK).
Experience Optimal Technology
This PCIe to serial adapter supports the following features:
Industry standard 16950 UART compatible
Supports max baud rate of up-to 921.6Kbps
Provides 5/12V power output on Pin 9 when external power is connected
256-byte depth FIFO cache per transmitter and receiver
Supports 9, 8, 7, 6, 5 data bits (one per port)
Asix AX99100 chipset
Base PCI Express 1.1 compliant
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
PEX2S953 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
Product Description StarTech.com 2 Port PCI Express RS232 Serial Adapter Card - 16950 UART - serial adapter
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.1
Ports RS-232 x 2
Dimensions (WxDxH) 7.5 cm
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Processor AX99100 - ASIX
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x - 2.6.x LTS versions only
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port PC...
£41.26
