Add 2 external or internal SATA 6 Gbps ports to a computer, through a PCI Express slot. The PEXESAT322I PCI Express SATA III Controller Card (6 Gbps) gives you the option to add 2 internal or external SATA ports to your computer, through a single PCI Express (x1) card slot. The card features on board jumper selection, which enables you to configure the card to provide 2 internal or external SATA III ports, or one of each, as needed.
The SATA III card features Port Multiplier (PM) support on each port, which allows multiple drives to be connected over a single cable when necessary to maximize the number of SATA device connections while reducing the amount of cabling required.
The card is fully compliant with the SATA revision 3.0 specification (up to 6 Gbps of data bandwidth), enabling you to utilize the speeds of high performance hard drives and Solid State Drives (SSD), as well as SATA-based optical drives (CD-ROM, DVD-ROM, Blu-Ray).
Product Description | StarTech.com 2 Port PCIe / PCI Express SATA III 6Gbps eSATA Controller Card - storage controller - SATA 6Gb/s / eSATA 6Gb/s - PCIe x1 | Device Type | Storage controller - plug-in card - low profile | Bus Type | PCIe x1 | Interface | SATA 6Gb/s / eSATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Channel Qty | 2 | System Requirements | Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits) | Dimensions (WxDxH) | 6.7 cm x 12.1 cm x 8 cm | Weight | 60 g | Manufacturer Warranty | 2-year warranty |
General | |
Host Bus | PCIe x1 |
Storage Controller | |
Channel Qty | 2 |
Expansion / Connectivity | |
Interfaces | 2 x eSATA 6Gb/s - eSATA (external) , 2 x SATA 6Gb/s - SATA (internal) |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Cables Included | 1 x Serial ATA cable |
Features | Native Command Queuing (NCQ) |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 6.7 cm |
Depth | 12.1 cm |
Height | 8 cm |
Weight | 60 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 5 - 85% |
