StarTech.com 2 Port PCI Express SATA III 6Gbps RAID Card w/ 2...
StarTech.com 2 Port PCI Express SATA III 6Gbps RAID Card w/ 2 mSATA Slots - storage controller (RAID)
£71.42
Delivery:
Standard: 1-3 working days
Key features
  • Supports HyperDuo SSD auto-tiering, merging SSD performance with HDD capacity
  • 2 mSATA SSD slots and 2 AHCI SATA III ports through PCI Express
  • Supports hardware RAID 0, 1, and 1+0 modes
  • Fully compliant with SATA 3.0 specifications and backward compatible with SATA I/II drives
  • Port Multiplier FIS-based and command-based switching supported
  • Compliant with PCI Express 2.0 standards
  • Supports TRIM command with compatible SSD and Operating System
  • Supports Native Command Queuing and ATA/ATAPI commands
  • On-board latching mSATA slots - SSD installation with no screws required
  • Supports HDDs/SSDs/optical/Blu-ray drives
  • Compatibility: Mac, PC
  • Stock Status: In Stock
Product codes
Combine SSD performance with HDD capacity to create a HyperDuo RAID array with 2 x mSATA and 2 x SATA drives through a single PCI Express slot. The PEXMSATA3422 PCI Express SATA Card helps you improve the overall speed and storage capacity of your computer by giving you multiple 6 Gbps SATA connections for connecting high-performance SSDs (Solid State Drives) and hard drives in a HyperDuo RAID array. Now, you can easily add two mSATA slots and two SATA III ports to your computer through a single PCIe x4 slot.
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
This versatile RAID controller card helps to relieve the internal space constraints often associated with multi-drive configurations by letting you install two mSATA SSDs directly to the card via convenient, latching slots. With dual mSATA slots, as well as two internal SATA ports, the card offers an effective hardware RAID solution, with native RAID (0, 1) support.
The PCIe SATA controller also offers Port Multiplier (PM) support, so you can connect multiple SATA drives to just one port, for a total of 7 drives (up to 4 drives through PM on one port, plus a single drive to the other SATA port and two mSATA slots).
For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
Product Description StarTech.com 2 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card w/ 2 mSATA Slots & HyperDuo SSD Tiering - PCIe SATA 3 Controller (PEXMSATA3422) - storage controller (RAID) - SATA 6Gb/s / mSATA - PCIe 2.0 x4
Device Type Storage controller (RAID) - plug-in card - low profile
Bus Type PCIe 2.0 x4
Interface SATA 6Gb/s / mSATA
Data Transfer Rate 6 Gbit/s
Supported Devices Disk array (RAID)
Channel Qty 4
RAID Level RAID 0, RAID 1, RAID 10, JBOD
System Requirements Linux, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Dimensions (WxDxH) 2 cm x 12.5 cm x 12 cm
Weight 60 g
Designed For P/N: ST521PMINT
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port PC...
£71.42
