StarTech.com 2-Port PCI RS232 Serial Adapter Card
£20.40
Delivery:
Standard: 1-3 working days
Key features
  • 2 PORT PCI RS232 SERIAL ADAPTER CARD: Controller card w/ 16C550 UART based on ASIX MCS9865, 2x DB9 ports w/bi-directional RS232 speeds up to 115.2Kbps/port, 256 byte FIFO buffer & 9th data bit | Upgraded version of our popular cards PCI2S550_LP & PCI2S550
  • TECH SPECS: Speeds up to 115.2Kbps | 16C550 UART | 256 byte FIFO buffer | 5,6,7,8 and 9 bit character | Even, Odd, No, Space or Mark Parity | Auto IRQ & IO assignment | Supports IRQ Sharing | ASIX MCS9865 Chip
  • VERSATILE APPLICATIONS: Dual Serial Port PCI Card for PCI desktops/servers used in point of sale terminals, PLCs, CNC Machines, control/automation in factories, scientific sensors, medical equipment, scanners, oscilloscope
  • STANDARD PROFILE & LOW PROFILE BRACKET: PCI multiport serial COM card installs using 1x standard bracket (pre-installed) or 2x low profile brackets (incl); Supports Windows 7 and up, Linux 2.6.x to 5.x
  • STARTECH.COM ADVANTAGE: IT professionals choice for over 30 years; PCI RS-232 Serial expansion card is backed for life by StarTech.com, incl. free 24/5 North America based multi-lingual tech support
  • Wired / Wireless: Wired
  • Protocol: RS-232
  • Type: Serial adapter
Product codes
This multiport PCI RS232 serial adapter card lets you add two RS232 (DB9) serial ports to your computer through a PCI slot, as if they were native serial ports. The dual port PCI serial card enables you to interact with serial devices, such as card readers, printers, PIN pads, and modems, at speeds of up to 115.2Kbps.
With broad OS support, including for Windows (7 and up), and Linux (2.6.x to 5.x LTS versions only), this 2 port PCI serial card is easy to integrate into mixed environments. The card comes pre-configured with a full-profile bracket, and includes optional low-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PCI2S550 LP and PCI2S550.
This PCI to serial adapter supports the following features: Industry standard 16C550 UART compatible; Supports baud rate up-to 115.2Kbps; 256-byte depth FIFO cache per transmitter and receiver; Supports 9, 8, 7, 6, 5 data bits (one per port); Asix MCS9865 chipset.
Low and full-profile brackets included.
Product Description StarTech.com 2-Port PCI RS232 Serial Adapter Card, PCI Serial Port Expansion Controller Card, PCI to Dual Serial DB9 Card, Standard (Installed) & Low Profile Brackets, Windows/Linux - Dual Port PCI Serial Card (PCI2S5502) - serial adapter - PCI - RS-232 x 2
Device Type Serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI
Ports RS-232 x 2
Dimensions (WxDxH) 2.16 cm x 13.4 cm x 12 cm
Weight 141 g
Cabling Type Serial RS-232
Data Link Protocol RS-232
Network / Transport Protocol SPP
Processor MCS9865
Compliant Standards 16C550 UART
Colour Black
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.x to 5.x LTS versions
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£20.40
