StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550...
StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART
£23.11
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with any PC running Windows, DOS or Linux for simple integration into your application
  • Data transfer rates of up to 115.2 Kbps for efficient serial device performance
  • Easy to install and use with full step-by-step instruction providing a hassle free serial solution
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: PCI
  • Stock Status: In Stock
Product codes
Documents
Add 2 high-speed RS-232 serial ports to your PC through a PCI expansion slot. The PCI2S550 2 Port 16550 Serial Card can be installed in an available PCI slot to add two RS232 serial ports to your system. A cost-effective solution for connecting any new or legacy serial device, with data transfer rates of up to 115.2 Kbps.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more to your system, the adapter card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux.
The card can be connected in minutes through simple plug and play installation.
Product Description StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART - serial adapter
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI
Ports RS-232 x 2
Data Link Protocol Serial
Data Transfer Rate 115.2 Kbps
System Requirements Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Resources
The following resources are available for the StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port PC...
£23.11
