StarTech.com 2 Port PCI RS422/485 Serial Adapter Card with 16...
StarTech.com 2 Port PCI RS422/485 Serial Adapter Card with 161050 UART
£68.49
Delivery:
Standard: 1-3 working days
Key features
  • Much larger FIFO buffer than standard serial cards (256 byte vs. 32 or 64 byte) minimizes data loss and optimizes host efficiency
  • A simple jumper change allows you to select either RS422 or RS485 serial interface formats specific to your application
  • Standard and low profile/half-height bracket included, ensuring easy installation into almost any system
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: PCI-X
  • Stock Status: In Stock
Product codes
The PCI2S4851050 2-Port PCI Serial Adapter Card (RS422/RS485) with 161050 UART adds two DB9 RS422/RS485 serial ports, using a single PCI expansion slot.
The PCI serial card offers a high performance 16C1050 UART and supports both 2-wire and 4-wire RS485 modes. The card delivers an efficient single-chip design and a large 256-byte transit/receive FIFO buffer that work together to provide high-speed serial communication while reducing the overall load on the system CPU.
With the included standard and low profile/half-height brackets, this PCI serial expansion card suits a broad range of system form factors, and is a perfect addition for connecting RS422/485 serial devices to a host computer. For added versatility, the RS422/RS485 adapter is able to accommodate 3.3 or 5V PCI/PCI-X slots.
Product Description StarTech.com 2 Port PCI RS422/485 Serial Adapter Card with 161050 UART - Serial adapter - PCI-X - RS-422/485 x 2 - PCI2S4851050 - serial adapter
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI-X
Ports RS-422/485 x 2
Dimensions (WxDxH) 4.5 cm x 12 cm x 1.8 cm
Weight 56 g
Data Link Protocol RS-422, RS-485
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port PC...
£68.49
