StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with...
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power
£50.80
Delivery:
Standard: 1-3 working days
Key features
  • Can support bus-powered USB devices
  • Faster transfer rates when used with USB 3.0 peripherals than a USB 2.0 host connection would permit (up to 1.3 Gbps, PCI bus limit)
  • Suited for installation in Small Form Factor cases as well as in full profile systems
  • Type: USB adapter
  • Compatibility: PC
  • Interface: PCI-X
  • Stock Status: In Stock
Product codes
Add 2 SuperSpeed USB 3.0 ports to a computer through a PCI slot. The PCIUSB3S22 2-Port PCI to USB 3.0 Card enables you to connect USB 3.0 peripherals to a PC through a legacy PCI host bus, which doubles the data transfer speeds when used with USB 3.0 peripherals than would be possible with a USB 2.0 host connection - up to 1.3 Gbps (PCI bus limit).
The card features an optional SATA power connection, which enables each port to supply up to 900mA of power to USB 3.0 bus-powered devices.
By supporting a legacy (PCI) host connection, the card adds updated peripheral connectivity, without having to upgrade to a PCIe-equipped motherboard or rely on the backward compatibility of USB 3.0 peripherals.
Product Description StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power - Dual Port PCI USB 3 Controller Card (PCIUSB3S22) - USB adapter
Device Type USB adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI-X
Bus Voltage Universal (3.3 V & 5.0 V)
Ports USB 3.0 x 2
Dimensions (WxDxH) 1 cm x 12.3 cm x 5.6 cm
Weight 60 g
Data Link Protocol USB, USB 2.0, USB 3.0
Data Transfer Rate 5 Gbps
Processor uPD720202 - NEC
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Colour Red
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Designed For P/N: S3510BMU33, S3510SMU33, ST7300USB3B, UNI251BMU33
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port PC...
£50.80
