StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card
£31.38
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Twice the speed of SATA II (3Gbps)
  • Ships with a full profile bracket install, low profile included
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
The PEXSAT32 2-Port PCI Express SATA 6 Gbps (SATA 3.0) Controller Card offers simple connectivity between a host computer and SATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the SATA 3.0 controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
Product Description StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card - Dual Port PCIe SATA III Card Adapter (PEXSAT32) - storage controller - SATA 6Gb/s - PCIe
Device Type Storage controller - plug-in card
Bus Type PCIe
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Hard drive
Channel Qty 2
Max Storage Devices Qty 2
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 3.5.x - 4.11.x LTS versions only
Dimensions (WxDxH) 64.5 cm x 67.7 cm x 21.3 cm
Weight 67.9 g
Designed For P/N: ST521PMINT
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port SA...
£31.38
