StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up t...
StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m)
£409.14
Delivery:
Notify me
Key features
  • Two USB 2.0 ports on remote unit over a single Cat5/Cat6 cable
  • Maximum extension distance of up to 100m (330ft) over Cat5 cabling
  • Rugged, metal enclosure with surface-mounting bracket kit included
  • High Speed USB 2.0 compliant with support for data transfer rates up to 480 Mbps
  • 500mA of power per port
  • No external power required at remote end as power is delivered over Cat5/Cat6
  • Type: USB Extender
  • Interface: USB, USB 2.0
  • Speed: 480Mbps
  • Ports: 2
  • Form Factor: External
Product codes
Extend two USB 2.0 connections with power, by up to 330ft over Cat5 or Cat6 cable. The USB2002EXT2 2-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). A local transmitter power adapter provides up to 500 mA of power per port with no power adapter required at the remote end, letting you access and power almost any USB 2.0 device in locations where a power outlet may be unavailable.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
Product Description StarTech.com Replaced by USB2002EXT2NA - 2 Port USB 2.0 over Cat5 or Cat6 Extender Kit - Local / Remote Power - 330 ft - USB Extender (USB2002EXT2) - USB extender - USB, USB 2.0
Device Type USB extender
Ports Qty 2
Form Factor External
Data Transfer Rate 480 Mbps
Data Link Protocol USB, USB 2.0
Transmission Medium CAT 5/6
Max Transfer Distance 100 m
Power AC 120/230 V
System Requirements Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0
Dimensions (WxDxH) 7.6 cm x 10 cm x 2.6 cm
Weight 0.6 kg
Designed For P/N: 35FCREADBK3
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£409.14
Notify me
