StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up t...
StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m)
£394.74
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Extend up to two USB 2.0 devices up to 100 m (330ft) over a single Cat5 cable
  • Connect USB devices at speeds up to 480 Mbps with 500mA of power without the use of a power adapter
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Type: USB Extender
  • Interface: USB, USB 2.0
  • Speed: 480Mbps
  • Ports: 2
  • Form Factor: External
Product codes
Extend two USB 2.0 connections with power, by up to 330ft over Cat5 or Cat6 cable. The USB2002EXT2 2-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). A local transmitter power adapter provides up to 500 mA of power per port with no power adapter required at the remote end, letting you access and power almost any USB 2.0 device in locations where a power outlet may be unavailable.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
Product Description StarTech.com 2 Port USB 2.0 over Cat5 or Cat6 Extender Local / Remote Power - USB extender - USB, USB 2.0
Device Type USB extender
Ports Qty 2
Form Factor External
Data Transfer Rate 480 Mbps
Data Link Protocol USB, USB 2.0
Max Transfer Distance 100 m
Power AC 120/230 V
System Requirements Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0
Dimensions (WxDxH) 7.6 cm x 10 cm x 2.6 cm
Weight 0.6 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port US...
£394.74
