StarTech.com 2 Port USB 3.0 A Female Low Profile Slot Plate A...
StarTech.com 2 Port USB 3.0 A Female Low Profile Slot Plate Adapter
£17.49
Delivery:
Key features
  • Adds two USB 3.0 A Female ports for faster transfer rates with USB 3.0 devices, while still supporting USB 2.0 and USB 1.1 devices
  • Easy to use and install
  • Two SuperSpeed USB 3.0 A Female ports
  • Ideal for small form factor computer cases
Product codes
The USB3SPLATELP 2-Port USB 3.0 A Female Low Profile Slot Plate converts the USB pins on a USB 3.0 motherboard header to 2 standard USB 3.0 A-style ports. An ideal solution for small form factor computer cases, the plate can be mounted on the rear panel of a low profile or thin client computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB3SPLATELP is ideal for small form factor computer cases. The USB 3.0 standard supports transfer rates of up to 5 Gbps, and provides connectivity and support for older USB 2.0 and 1.1 devices.
Product Description StarTech.com 2 Port USB 3.0 A Female Low Profile Slot Plate Adapter - USB panel - 50 cm
Type USB panel
Technology Shielded
Features Low profile
Length 50 cm
Connector 2 x 9 pin USB Type A - female
Connector (Second End) 20 pin IDC - female
Compliant Standards USB 3.0
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port US...
£17.49
