StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter
£17.16
23 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
The USB3SPLATE 2-port USB 3.0 A slot plate converts the USB pins on the USB 3.0 motherboard header to 2 standard USB 3.0 A-type ports. The plate can be mounted on the rear panel of a computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB 3.0 standard supports transfer rates of up to 5Gbps, and provides connectivity and support for older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
Product Description StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter - USB panel - 50 cm
Type USB panel
Technology Double shielded
Length 50 cm
Connector 2 x 9 pin USB Type A - female
Connector (Second End) 20 pin IDC - female
Compliant Standards USB / USB 2.0 / USB 3.0
Colour Blue
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port US...
£17.16
