StarTech.com 2 port USB 3.0 C Hub with Power Delivery 2.0
£24.16
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Interface: USB 3.1 Type C
  • Ports: 2
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £27.65
Save £1.50
Turn your laptop's USB Type-C port into one USB Type-A and one USB Type-C port (5Gbps), plus power and charge your laptop. This 2-port USB 3.0 hub lets you connect a wider range of peripherals to your MacBook Pro, MacBook and other USB-C laptops. The hub expands your laptop or desktop connectivity by enabling you to connect both USB-A and USB-C devices through a single USB Type-C or Thunderbolt 3 port.
The compact USB-C hub supports USB Power Delivery, which means that you can power and charge your MacBook Pro, MacBook and other USB Type-C laptops through its USB-C port while simultaneously powering the hub.
Extend the life of your current USB 3.0 devices and take advantage of newer devices that feature USB-C.
This USB 3.0 hub lets you expand your USB connection options using the USB-C port on your computer. It offers one USB-A port and one USB-C port, so you can connect traditional USB devices as well as newer USB-C devices to your USB-C laptop.
You can travel lighter, with a single USB-C adapter that lets you connect virtually any USB peripheral.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. The hub is ideal for use in hot-desk or BYOD (Bring Your Own Device) environments.
For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
This USB-C expansion hub is multi-platform compatible, which means it will work with a wide range of operating systems such as Windows, macOS, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Product Description StarTech.com USB to USB C Adapter - with Power Delivery (USB PD) - Compact - USB C Converter - USB-A to USB-C Adapter - USB C Port Adapter (HB30C1A1CPD) - hub - 2 ports
Device Type Hub - 2 ports
Subtype USB
Ports 2 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 port US...
£24.16
