StarTech.com 2 Port USB 3.1 Card - 2x A
£31.18
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Add two 10Gbps USB Type-A ports to your computer, through a PCI Express slot. This USB 3.1 card lets you add two USB Type-A ports to your computer, through a PCI Express slot. It enables you to upgrade your current system by adding two USB 3.1 Gen 2 ports to your computer and giving you access to data transfer speeds up to 10Gbps.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2 and rest assured you're ready for both current and future high-bandwidth USB-A devices.
With higher data throughput support, this PCI Express USB 3.1 card is a necessity for external drives, drive enclosures, and many other USB 3.1 peripherals. Plus, the USB card includes an optional SATA power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.1 bus-powered devices (500mA for USB 2.0). The card is ideal for use with large external storage solutions.
Connecting older peripherals isn't a problem. This versatile dual-port USB 3.1 card is backward compatible with legacy USB 3.0/2.0 devices that use the common USB Type-A port, so you can eliminate the added expense and aggravation of purchasing new devices.
The USB 3.1 PCIe card is compatible with a broad range of Windows and Linux operating systems. Plus, the high-quality card includes both standard-profile and low-profile brackets, making it easy to install in full or small form-factor PCs and servers.
Product Description StarTech.com Dual-Port USB 3.1 Card - 10Gbps per port - 2x USB-A - PCIe - USB adapter
Device Type USB adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express 3.0 x4
Ports USB 3.1 Gen 2 x 2
Dimensions (WxDxH) 1.08 cm x 12.2 cm x 2.1 cm
Weight 50 g
Data Link Protocol USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate 10 Gbps
Processor ASM2142 - ASMedia
Compliant Standards xHCI
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.4.x LTS versions
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port US...
£31.18
