StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter
£7.45
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Add two external USB 2.0 ports to your small form factor PC. The USBPLATELP 2 Port Low Profile USB Bracket converts the USB pins on a USB 2.0 motherboard header to 2 standard USB A ports.
An ideal solution for small form factor computer cases, the slot plate can be mounted on the rear panel of your low profile or thin client computer case - adding two USB female ports for simple connection to USB peripheral devices.
Product Description StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter - 2 Port USB Bracket - USB 2.0 A Female (USBPLATELP) - USB panel
Type USB panel
Connector 2 x 4 pin USB Type A - female
Connector (Second End) 2 x 5 pin in-line - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port US...
£7.45
