StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter w...
StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention
£82.14
22 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
The ICUSB2324852 2-port, wall-mountable USB Serial Adapter lets you connect every type of serial device to your USB-enabled computer, whether it be for RS232, RS422, or RS485 communication. The adapter features a 9-pin (DB9) male and a 5-pin terminal block serial connector as well as dipswitch controls for easy port configuration with minimal software requirements. The adapter also supports using 2 ports simultaneously, including with mixed protocols; for example RS-232 on port 1, and RS-485 on port 2, or a number of other combinations.
For a convenient, and clean installation in an office or industrial setting, the RS232/RS422/RS485 USB Adapter is wall-mountable and fully powered via the host USB connection, providing power to the attached serial device without requiring an external power adapter.
Product Description StarTech.com USB to Serial Adapter - 2 Port - RS232 RS422 RS485 - COM Port Retention - FTDI USB to Serial Adapter - USB Serial (ICUSB2324852) - serial adapter - 2 ports
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 4.4 cm x 8.2 cm x 2.3 cm
Weight 300 g
Ports Qty 2 ports
Data Link Protocol RS-232, RS-422, RS-485
Data Transfer Rate 921.6 Kbps
Colour Grey
System Requirements Apple MacOS 6.0, Linux 2.4 or later, Microsoft Windows XP Embedded, Microsoft Windows 98SE/2000/ME/XP, Apple MacOS 9.x or later, Microsoft Windows 7, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Vista, Microsoft Windows Mobile 6.0, Microsoft Windows 2003, Microsoft Windows Server 2008, Microsoft Windows CE 6.0
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port US...
£82.14
