StarTech.com 2 Port VGA Video Splitter with Audio - USB Powered
LAST FEW REMAINING
PRICE DROP
£20.94
Delivery:
Product codes
A compact, USB powered solution for extending a high-resolution VGA signal from a computer between 2 monitors/displays or projectors.
The ST122LEA 2 port VGA video splitter with audio and USB power is the most compact VGA splitter, allowing a computer to simultaneously display VGA video on two monitors from a single source.
Support for resolutions up to 2048x1536 resolution and stereo audio makes this device perfect for classrooms, tradeshows, or any environment requiring high quality video on several displays.
This VGA splitter is able to draw power from your source PC or media player using an available USB port, instead of using a conventional power adapter making it easy to install where power outlets are not available. The splitter also features a built-in booster circuit that allows you to locate VGA monitors up to 200ft away from your system.
Product Description StarTech.com 2 Port VGA Video Splitter with Audio - USB Powered - compact VGA Splitter - Dual Port VGA Splitter USB powered (ST122LEA) - video/audio splitter - 2 ports
Device Type Video/audio splitter - 2 ports
Subtype VGA / audio
Ports 2 x VGA + 2 x audio
Features USB powered
Dimensions (WxDxH) 5.3 cm x 6.8 cm x 2.3 cm
Weight 115 g
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port VG...
£20.94
