StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub...
StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention
£42.88
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Multiple ports with COM port retention give you hassle-free control of several serial devices without having to remember where each one was last connected
  • Rugged all-metal enclosure for added durability in harsh environments
  • Easy plug and play installation with our USB Powered adapter - no power outlet required
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: USB
  • Stock Status: In Stock
Product codes
The ICUSB2322X 2 Port Professional Grade USB Serial Adapter converts a single USB port to two RS232 serial ports allowing you to connect to, monitor and control your serial devices. Rugged metal construction and sturdy wall-mount brackets provide a robust solution for both harsh industrial environments and simple desktop installations. Powered by USB, the device does not require a power outlet for most standard applications. For installations requiring more power through the RS232 ports, the hub supports connection of an external power adapter (not included) to the integrated DC jack or terminal block. Once connected, the adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the ports provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading serial peripherals for USB compatibility.
Product Description StarTech.com USB to Serial Adapter - 2 Port - Wall Mount - COM Port Retention - Texas Instruments - USB to Serial RS232 Adapter (ICUSB2322X) - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB
Ports RS-232 x 2
Dimensions (WxDxH) 11.3 cm x 8 cm x 2.3 cm
Weight 300 g
Data Link Protocol RS-232
Data Transfer Rate 230 Kbps
Colour Black
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port Wa...
£42.88
